View the status of OSPFv3 route redistribution to verify the current configuration. You can redistribute directly connected routes and IPv6 static routes into OSPFv3.
Switch:1#show ipv6 ospf redistribute
OSPFv3 Redistribute List - GlobalRouter
SOURCE MET MTYPE ENABLE RPOLICY
Static 0 external TRUE
Use the data in the following table to use the show ipv6 ospf redistribute command.
Variable |
Value |
vrf WORD<1-16> |
Specifies the VRF name. |
vrfids WORD<0-512> |
Specifies VRF IDs. |
